Help wantet for nice tree roots
would like to create even better roots for the Cararra trees in the vicinity, what is the best way to do this, maybe there is a tutorial for this. I know that it doesn't work with the plant editor. thanks
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,440
    another tree upsidedown
  • UnifiedBrainUnifiedBrain Posts: 3,588
    What Wendy said.  That, plus Fenric's Ivy Generator.
    https://sharecg.com/v/44242/Software-and-Tools/Ivy-Generator-For-Carrara
  • HeadwaxHeadwax Posts: 10,456
    check out the organic part of model room
    ie outine roots with polyline, select them thenm click construct>organic , then fix the result :)
  • StezzaStezza Posts: 8,859
    edited June 2022
    what @Headwax says
    I do a rough shape of roots with the polyline then push them up and down then fill then use the construct-organic tool
    then I untriangulate and smooth and fix the weird bits... there's always weird bits wink
    640 x 480 - 129K
    640 x 480 - 485K
    Post edited by Stezza on
    nice work Stezza.!
    there's also some examples in this thread Carrara Monthly Challenge: Fabulous Prizes! VOTING NOW OPEN! - Daz 3D Forums  @Khoe
  • KhoeKhoe Posts: 341
    Thanks at all.
    I test ist. Some gut idees.
  • GrimmvaldGrimmvald Posts: 65
    I'm late to the game here but Lisa's creepy trees have some nice, ugly roots.  There were several versions of these.  Looks like Daz store doesn't have them anymore but just checked Renderosity and they are still available.  I assume 8.5 still takes .obj files.  Maybe put them in modelimg room and chop off the parts they you don't want
    Or if it works with the rest of your scene just chop off the top in whatever editing program you use.  Or could they be rendered on own layer an be trimmed on that layer?  Haven't used that in a loooong time.
  • ed3Ded3D Posts: 2,532
    And Then >
    Xfrog Plants   _ perhaps ,  thanx
  • copy your 10.00 ft tree size tree
    z flip copy tree
    clear leaf
    trunk length 1
    tree size 3 ft
    trunk width 5
    in roots 0 flare & 0 lobes
    internode leangth 1
    branches:
    length modifier 1
    negative angle modifier
    z flip copy tree
    clear leaf
    trunk length 1
    tree size 3 ft
    trunk width 5
    internode leangth 1
    branches:
    length modifier 1
    looks very interesting, do you have a picture? I don't quite understand.
  • those are thing to change in the plant editor to the fliped copy tree.
    this is how the outcome looks.
    1920 x 1440 - 2M
    Thanks
    i have the same result.
    edited June 2022
    OK. I did some experiments and found the following solution. First the tree created without a root. Then duplicated the tree and now only set 1 generation in the plant editor. Then changed the trunk so that it gave a nice shape. all settings affecting the appearance of branches to 0. now back out of the editor, tilted the trunk by 90° and duplicated it 5 times, then placed it around the tree and changed everything in the editor. Finally, the branches are placed from further copies of the roots.
    if I want to place the tree I have to lower it further or adjust the roots.
    1200 x 900 - 186K
    Post edited by Khoe on
