Need help with GoZ for Daz
Hello,
my GoZ Plugin for Daz doesn't work. I installed it via IM and it shows me the intalled path, but I can't find it
Can somebody help me please?
  • hansolocambohansolocambo Posts: 649
    edited June 2022
    Many threads on the subject.
    I wrote about the steps for a proper GoZ installation here. Maybe check that first ;)
    https://www.daz3d.com/forums/discussion/387741/daz-file-send-to-zbrush-crash-since-update-to-zbrush-2020
    Post edited by hansolocambo on
  • Richard HaseltineRichard Haseltine Posts: 108,127
    Can't find it in the File menu in Daz Studio (File>Send To>Send to ZBrush)? Is it in Help>About Installed Plug-ins?
  • FantastArtFantastArt Posts: 372
    Thank you but this doesn't solved it!
     I checked this and it says that the plugin failed to load because it's not the right version....so what can I do? This is the version I get via IM
    FantastArt said:
    1388 x 1080 - 219K
    The version of Daz Studio and any Daz-branded plug-ins must match, presumably you are using an older version of DS (Help>About Daz Studio) in which case you need to update to 4.20.0.17
     Thank you for the tip, I updatet Daz Studio now. Unfortunately GoZ is installed, but doesn't find ZBrush now
    1920 x 1080 - 756K
    The latest version of ZBrush is installed on my PC correctly
    1920 x 1080 - 497K
    1920 x 1080 - 484K
    Sooo! Ok, I solved the problem. It has to be the english version installed! Ihis is something I don't think is very nice because if you have your own language installed all of the tools won't work. I think hat's stupid
