"Outline" render script only renders plain white
Hi,
I'm having a problem with the render script "outline" as it's the only one not really working and I don't really know why. Like the attached picture shows, it only renders in complete white, like a silhouette. I use the default lightning setup when creating a new scene.
I'm sure it must be a simple solution but I'm bit lost and haven't found a solution on the web :)
  • Richard HaseltineRichard Haseltine Posts: 109,533
    How is it meant to render?
  • giovannipaologiovannipaolo Posts: 249
    Greetings! Try saving the file, closing and reopening. It might be a memory issue. :coolsmile:
  • edited December 1969
    Problem partially resolved as I didn't find a solution for this renderer but got the results I wanted through the toonycam asset.
    Case closed :)
  • BalooBaloo Posts: 71
    In case oyu don't get what you what with Tooncam: you're not making any mistake, you're simply looking at the render output instead of the 3 files created while rendering. Their path is specified in Renderer Files / Outline directory just below the Scripted 3Delight selection.
    I've put a screenshot here.
    Cheers
  • MartirillaMartirilla Posts: 191
    edited July 2022
    In case someone finds this in the future: the solution is that you need to set the Rendered Files | Outline Directory. If the outline renders have nowhere to go, then the user gets nothing other than a single white silhouette render. This output path is different than the one in the main render settings ('Image path').
    Post edited by Martirilla on
