Skin popping through outfit in render but only for a second in preview render.
Hello, New to Daz3d and mainly the rendering and know how. I come from the Gmod posing world so its a whole new beast.
I seem to be having the trouble of in preview he renders perfectly and his skin doesn't poke out, however in the render there are patches of skin out. I tried to see if it were the shape size but no luck.
Would anyone know how to fix this?
  • Richard HaseltineRichard Haseltine Posts: 108,598
    That is probably down to dispalcement, movement of the mesh vertices according to the colour of a map or pattern which works on the viewport resolution mesh in preview and the, usually higher, render resolution in renders so it can show different results. You can try moving the clothes (e.g. with a Push Modifier) or, in a case like this, just hide the underllying body parts (click the eye next to them in the Scene pane, or select several and use the Visible button in the Parameters pane).
