Victoria 6 does not appear
floppinofloppino Posts: 0
Hello I am Italian I have a problem with Victoria 6
Installing poser 2014
Victoria 6
DSON imported 1.1.3
Genesis Starter Essentials
But qunado load 6 victoria in poser not I get no shape although it appears in the menu
    Well, for a start I see the scale is set to 0%, which means she would be condensed to the size of a single vertex. Try rescaling to see if she becomes visible.
  • Richard HaseltineRichard Haseltine Posts: 109,018
    Did you install both the DSON core and the PoserCF packages? The former has the geometry, morphs and textures - the latter just the library files.
    V6 is based off of Genesis 2 Female, did you install Genesis 2 Female Starter Essentials?
