RY Yeanny materials option missing
From the description, the items should have both uber and pbr mats, but only pbr are available.
"You can either use the Genesis 8.1 PBR shader for stunning realism or the good old Iray shader."
  • FSMCDesignsFSMCDesigns Posts: 12,844
    It's probably just the way it is worded since I see no options for both types of textures in the description or the readme. Also according to the readme it only lists one set of textures and they are for the base female UV and not 8.1, so technically it doesn't seem to be an actual 8.1 female character
  • Richard HaseltineRichard Haseltine Posts: 108,263
    Sent in a query on this.
    This is being looked into.
  • ioonrxoonioonrxoon Posts: 896
    @FSMCDesigns They can still be left out by daz like they did with the poser version of a product a few days ago; or maybe it's an older description and they were intended to be part of the product but removed. I don't see any reason to write that, unless there's plans to add both option. Either way, this should be fixed or at least the description changed.
    @Richard Haseltine Thanks!
    Apparently the text was a relic, this character has only the PBR materials. The text is being corrected, if the Uber Base materials were essentail for your purchase please open a Sales support ticket.
