Prop's position changes when I renders
TheCedizTheCediz Posts: 172
Hi,
I've made a simple nose to ear chain out of the geometrie of a product I had (the armchain thing in the images below; for personnal use only). Part of the thingy was modified in Hexagon and sent back to Daz.
First image here is a screencap of the viewport on Iray preview. The second one is a spot render (a normal render has the same effect). Anyone can tell why the position of the chain changes?
TY
Post edited by TheCediz on
  • felisfelis Posts: 6,147
    How is the chain attached?
    There is some weirdness with Rigid Follower Nodes and subD.
    If with a rigid follower node, is the node then on a face bone or on the character?
  • TheCedizTheCediz Posts: 172
    So as of now the ear-nose chain is composed of 3 separated objects: 2 rings (simple torus) and the chain part. I am actually using a node from another nose piercing product; deleted the piercing and parented all 3 objects to the node. The node is probably a rigid follow node yes.
