GENESIS 8.1 BROKEN MALE BODY
daortega82daortega82 Posts: 12
I have a problem with the body of genesis 8.1 male. Why is this happening and how can I fix it?
    In Parameters Tab, enable "Show Hidden Parameters" and select "Currently used", the list will show you all the dials that are at non-default value, one of the hidden ones (hard to read the label) is the culprit.
    Try changing the values on the hidden dials to see which one.
  • Richard HaseltineRichard Haseltine Posts: 109,279
    edited June 2022
    Moved to technicasl Help as it is not a Daz Studio question but a content question.
    Reply to duplicate post made to Genesis 8.1 looks broken merged into this thread.
    In addition to the above check to see that you have the current versions of your cintent - that looks like to be an error in set up, and those usually get fixed fairly quickly if they are content from Daz or other marketplaces.
  • FenixPhoenixFenixPhoenix Posts: 3,191
    That means a character/morph might have been saved correctly and it's being dialed in on the base Genesis 8.1 Body. Try:
    1. Load a Genesis 8.1 Base character.
    2. Open the parameters tab (window > tab > parameters) and click on currently used.
    3. Check to see if there's something being dialed up as a morph.
    4. If you don't see anything amiss, click on the hamburger icon (three lines and an arrow in the upper right corner) of the parameter tab > preferences > show hidden.
    5. Now, select again currently used, and check what's being dialed. If again, nothing looks amiss. Try posing the character and see what JCMs is being dialed.
    6. If a JCM from a character is loading up, then you know that character wasn't saved correctly. Uninstalling that character will fix the issue.
