Is There a Permanent Solution for Jaggy Dforce Result?
James
I know the problem caused by topology.
I've watched DAZ3D Video solutions to apply subd and geometry tool.
Subd basically trianggulates the quads.
Geometry tool to change the direction of the tris.
But is there a permanent solution, So I don't have to subd and use geometry tool for each different poses?
Post edited by James on
Have you enabled smoothing on the clothing?
Nope, any subdivision divide each polygon, if triangualr you get 3 polygons if quad 4. exponentially by each subd level
Referring to your attachment, it looks like there is no subd applied to the cloth, you can see the subd on the character but not on the cloth.
