Is there a way to make Dforce effect not symetrical?
James
Is there a way to make Dforce effect not symetrical to make it more natural?
Post edited by James on
James
If you use a slightly non symetrical pose instead of the zero pose, the result will be better and non symetrical.
If you want to force a non symetrical result, even with a perfecly symmetrical pose, you can try to use with dforce weight maps
You can also add a dforce wind node.
