Poser suddenly changed it's display?
Upirium
PP2014 crashed when I tried to load it, and I loaded it again and...of course, I did not read it, but it said something about a display, and MAYBE Open DL? Now it looks like this...
It's not RIGHT it's not how it was and I do not like it.
How do I fix this? Please. I can't stand it.
I will post an example of what it was before and what it is now and iti s NOT THE SAME.
First pic is now
second is before
Different programs, but this LITERALLY JUST HAPPENED and I cannot work like this.
edit:
I think I fixed it, under render settings. It was Open GL I think that unloaded itself? And it was like spreeSD or something?
And I turned it back to Open GL and now it's okay but is this going to cause problems for me later?
The crash probably affected the computer's display driver. Or the driver itself may have crashed, and That's what then caused Poser to crash. You did the right thing, and you should be fine.
I believe Poser has two display options, OpenGL and the other is software based built in to Poser. I don't recall the name of the built in one but it begins with an "S".
