Daz won't render after 4.2 update
ILJackson
I just updated to 4.2 and tried several preload scenes and a couple saved scenes which I had just rendered days before. In every case the rendering process happened instantly and I got a black window or a window showing an empty layer, as if a .png. I've messed with the camera headlights and looked for something that may be causing this, but I can't seem to find it.
It's four point twenty, not four point two (which never was)
Did you update your GPU drivers?
Which GPU?
How is your scene lighted?
If with meshlights (ghost lights) Nvidia changed how they work
It was the drivers, thanks! And I thought it was 4.2 because I always saw the preceding versions as fractions of 4.1 building up to 4.2, so I thought 4.16 was like in-between the 4.1 and 4.2 builds... I'll have to adjust that in my head now.
