DIM wit? Problems with Install Manager [SOLVED]
3WC
Apologies if this is answered elsewhere. I did a quick search but turned up nothing.
I fired up DIM today to download and install my latest purchases, only to have it tell me that I have zero files installed, and hundreds ready to download (basically, everything I've ever bought from DAZ). So, what happened? I opened Studio, and all the files are showing up. I checked to see if CMS is running. It is. I even rebooted my computer. Still zero files installed, 817 ready to download.
Thanks for any solution you are able to offer.
Post edited by 3WC on
The information on what DIM has installed is in C:\Users\Public\Documents\DAZ 3D\InstallManager\ManifestFiles -- are you seeing .dsx files there for each zip?
Oooops! Looks like that folder got deleted. Fortunately I was able to restore it from the recycle bin, and now is all as it should be.
Leading to another question: is it possible to move that folder out of Public Folders where it's less likely to be tampered with?
Yes, if you go to C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts there will be an .ini file for your account, Close DIM and edit the .ini file line that reads:
OverrideManifestDir=
to add the new path, and move the contents of the old ManifestFiles folder there, then when you start DIM it will look in the new path.
Ok, that worked, finally. I originally copied the path direct from windows explorer, and it copied in with back slashes. DIM didn't like that, kept overwriting it with gibberish. When I noticed that other paths in the .ini file had forward slashes, I changed them and all is well.
