Strange Behavior
jerryjvjerryjv Posts: 0
I'm getting this.  I'm not sure what I need to change to fix it.
I am using the Package   Super Hero Suit for Genesis 2 Male(s) and Michael 6 | Daz 3D  by smay.  I am using it on a base Genesis 2 male.
Any help would be apreciated.
Thanks,
Jerry
  • Richard HaseltineRichard Haseltine Posts: 109,174
    Does it render like that?
  • Lee MoonLee Moon Posts: 927
    I have the same outift.  To solve that, I applied a smoothing modifier to the object.  Cleaned it right up. :)
    Lee
  • jerryjvjerryjv Posts: 0
    Lee
    Lee,
    I am new to Daz, and I thought I saw something similar somewhere else.  What I do not know how to do, is to add the smoothing modifier to the object.  And which object are you suggesting it be added to, the figure, or the 'suit'?
    Thanks.
    Jerry
    I am not sure.
    I am still very new to Daz, and not sure that I understand everything that I need to know.
    I am mostly using Daz to create characters to transfer to Unity, to create custom assets for use on Tabletop Simulator.
    Lee
    Lee,
    Thanks.
    Jerry
    Select the suit, then Edit>Figure>Geometry>Apply Smoothing Modifier.
    I am not sure.
    Render>Render (cmd(Mac)/ctrl(Win) R) will do a render, which may not show the issue depending on the cause.
    Lee
    Lee,
    Thanks.
    Jerry
    Thank you Lee!!!!
    I was stuck trying to use things off of a right click, or in the panel on the side.  I just couldn't find a way to modify it.
    It was a quick fix, with your help....  It would have been nice if I had actually looked at the 'edit' button.  Oh, so many things there to play with.  :)
    Thanks again!
    Jerry
