How to start Content Management Services
rampart_1576840087rampart_1576840087 Posts: 504
edited January 2015 in Carrara Discussion
Note in first attachment I found the content management start.exe, but it doesn't start because the services is not enabled.
When I go into Task Manager and try to start daz content management service - I get an access denied popup.
I have administrator permissions for the computer using windows 7 OS.
Here are some screen captures
I searched around abit on the web, but thought it best to just post here.
The problem relates specifically to a Daz application.
I would appreciate some links or discussion on ways to resolve this.
The smart content is not available without proper installation.
Post edited by rampart_1576840087 on
  • chickenmanchickenman Posts: 1,202
    Since I am on Win 8 my content managemnt service is not running by default, so I must start it manually.
    I do this by running the Start DAZ Content service as you depict in the first screenshot.
    I have it saved to my desktop so I can quickly start it wait a moment after it is started then I am good.
    If I am using the Beta It also has to be running the I can still conect to the DB even though it is suing the POSTGre DB and not the Valentia DB.
  • rampart_1576840087rampart_1576840087 Posts: 504
    edited January 2015
    I can't get content management to start,because the service must be running.
    I always show the service not running until I run the file indicated then it will sho that it is running as it actually starts the Service.
