Cheap program for super-boolean welds?
NightmareHeroNightmareHero Posts: 18
edited December 1969 in Product Suggestions
Is there any program for $70 to $50 or less that does super-boolean welds to turn primative modeled designs into unimeshes?
    edited January 2015
    That is not usually a good workflow for base modeling, but Blender does do booleans and is free.
    Post edited by SickleYield on
  • stem_athomestem_athome Posts: 526
    With polygon boolean operations, you will always have some issues.
    For your price_range, I would suggest you have a look at Groboto. http://www.groboto.com/v3/
    You can get Groboto V3.3 for $40 http://www.groboto.com/v3/Store/Offers_3/index.html
    Be aware. Groboto development is probably finished now. The developers moved to creating a plugin (MeshFushion) for Modo. That now appears to be their main concern.
  • jpb06tjpb06t Posts: 272
    He wrote that he is seriously ill and that he is dedicating 100% to the Modo plugin.
    Blender booleans since the inclusion of the Carve library are pretty good.
    latego said:
    He wrote that he is seriously ill and that he is dedicating 100% to the Modo plugin.Too ill to finish Groboto, but well enough to start / finish a major project (Meshfushion).
    All reasoning aside, Groboto is unlikly to be developt further.
    Although Carve CSG is certainly robust (and a number of applications now use that library), unless the user makes sure of edge alignment at trimming boundaries, there will be issues with bad poly flow and a non-watertight mesh. Which leads to (but not limited to ) rendering artifacts.
    I don't remember the exact disease he said he suffered from, it was a blood disease and the relevant wikipedia page was quite clear: chronic, progressive and eventually, in 10-20 years, fatal. This guys knows the answer to the question "how will I die".
    Going back to booleans, some edge flow refactoring/retopo is inevitable whenever you use booleans, in any application.
