I Can No Longer Export My Millinium Cat LE Morphs.
rampapandiontinling_89ac0508ff
So I installed the latest version of DAZ, 4.20, on a new computer.
I had an old Milliinium Cat LE figure that I wanted to export. It comes with subset of morphs from the full cat figure, plus visemes. In previous DAZ, 4.15, I was able to export all the morphs by setting the correct morph rule in the FBX export. It seems the morphs cannot export in 4.20.
Have some figures been restricted for what can be exported?
the LE version does not have the breed morphs
(Limited Edition)
also to export the visemes they need to be baked to timeline not at 0 seconds
Thanks Wendy. But what about all the other expression morphs. If I click on the head, for instance, there is a huge list of morphs in the Shaping tab. I do remember previously being able to export these. Did licensing change, or something?
you still would need to bake them to the timeline to see them in expression editor
I only use iC6 so cannot really help you with later stuff but FBX is FBX unless you use the DAZ to Unreal Plugin to export it with it's morphs option, I use that for my 3DX6 FBX imports
