Any DSF Toolbox users that can help?
I recently got the DSF toolbox to attempt my own wardrobe making in Blender. I've managed to export a figure and made a simple skirt. My question is, is there any detailed tutorial about how to use the program? When I try to export OBJ to something else, I get the error popup for templates, UVs, channels, and all kinds of stuff. What exactly do I have to do to export a piece of clothing back in to DUF/DSF/MTL? I don't want to mess anything up in my main files directory, and there are no explanations for the 8 tabs in the utility.
Also, if I use the bones in Blender on the clothing, will it import correctly into DAZ? I managed to get a rough clothing item into DAZ but it will not 'fit to', nor will it adapt to poses. So I'll need a crash course in rigging too, right?
From my understanding, bones will not transfer over correctly (if at all) but what you do once you get your skirt in daz is
select the skirt then
go to edit -> object -> rigging -> convert prop to figure (*edit* keep the default triax weight map selected)
Load a genesis or genesis2 female
go to edit -> figure -> transfer utility
on the left selection, select the genesis character
on the right select the skirt
click ok and it will transfer the rigging from the genesis model to the skirt.
