Do you know of any models with good armpit texture?
in The Commons
Do you know of any models with good/ realistic armpit texture? I notice a lot of the underarm in daz (namely female) just have a smooth, unrealistic appearance, whereas in real life they look sort of jaggedy and darker even.
You can always edit the textures in an image editing software like photoshop or GIMP
Thank you! I understand I can open a file on gimp and add a texture, but how would I go about that? Where would I find a texture to subtly add it to the armpit area?
I think the armpit is part of the torso. And if so hoover over the base color map and it will give you the file location.
You might also wamt to modify some of the other maps, and they are in the same folder, to give a better effect.
I would paint the hair on a new layer, and then you can apply similar changes to different maps.
When done save the file with a new name, and in the surface tab, select browse and go to your new map.
I have no idea where to find an armpit image, but I'd be surprised if there isn't a fetish site solely dedicated to armpits... Aside from that there are numerous tutorials on YouTube that explain the basics of editing UV maps.
Dark elf Binah is the only one that comes to my mind
