"Elora" drives load times up to 10 minutes
I just figured what's causing my load times isn't so much wonky 3rd parties but Elora:
https://www.daz3d.com/elora-for-genesis-8-female
The logfile is full of "Duplicate Formula found linking zEnd & Elora Body in [path to dsf file]"
owner: Genesis8Female
Output: lPectoral.... ? end_point/z
input: [path]?value
Or maybe it is some 3rd party thing, but I don't know where to start. Screenshot with a bit of the output attached. I uninstalled the package and now scenes load in under 2 minutes.
  • Richard HaseltineRichard Haseltine Posts: 108,598
    That almost certainly means you have another character or shape named Elora installed, and the issue is that both use the same property name and both make joint adjustments. Do report this to Daz as, ideally, the name should have additional vendor-specific bits to help avoid such issues but it isn't actaully a bug in the character per se. I have Elora installed without issue.
  • Jason GalterioJason Galterio Posts: 2,562
    Elora has / had a conflict with Whimsical Teens for Genesis 8 Female.
    I thought this was resolved though; 10-18-2021 - Fixed an issue where the Elora morph was causing a duplicate ID error.
    From: http://docs.daz3d.com/doku.php/public/read_me/index/80422/start
    I recognized the error immediately after seeing the title of your message.
  • pixelquackpixelquack Posts: 351
    Will do, but I'd like to be able to tell what it collides with. Any way to figure it out? Entirely possible it's some freebie 3rd party thing I don't even use; in general I'm with you on unique names.
    I don't have that package, must be something else.
    Renderosity has a few Eloras
