Does anyone know what couch / sofa this is?
Kevin Rye
I'm looking for the sofa used in these promos. It's not listed in the Notes for the page. There is a link for "Treasures of Egypt (old)" but the link is broken. I hope that's not it. Does anyone know what couch this is?
https://www.daz3d.com/poses-of-egypt-for-genesis-8-female
Thanks
Post edited by Chohole on
I have been looking through my library for that couch, it is familiar, but haven't found it yet. I can't get it out of my mind I saw it in the PC+ sales. There are other lounging, or fainting couches, in the store.
I do have the Treasures of Egypt which are lovely, and yes old, but still in the store. There is also the Treasures of Egypt 2, which has that big vase.
Mary
...yeah it looks very familiar, but searching both here and even at the other store turned up nothing. The only other possibilities is that it is so old and thus has been vaulted (and likely given new Iray textures for the promo) or may be a kitbash.
I thought that there was a half-backed sofa-chair like that that might have come with a pose set, but I can't find it. There is an old classic still kicking around that could do. Flight of the Swan and the Elegance for Flight of the Swan add-on are more art deco / art nouveau, but has the basic shape, and with some re-texturing...
...Flight of the Swan was what first that came to mind as well.
Pose set with a Chaise Longue (or "chaise lounge" for the dyslexic)? There are more than one of those by Zeddicus, but it's not the same chair.
https://www.daz3d.com/z-chaise-lounge-quick-environment-and-poses
https://www.daz3d.com/z-chaise-lounge-prop-pose-collection
I don't think I have that particular chaise, but as said, there are many such chairs in the store.
https://www.daz3d.com/ig-elegant-charm-prop-set-and-poses-for-genesis-8-females
https://www.daz3d.com/igdr-diva-room
...also looked through ShareCG, Rendo Freebies, Turbosquid, and CGTrader, yet still came up empty handed which makes me wonder if it maybe isn't a custom model.
Makes me think of the Chaise Room by Richabri at 'Rotica, but the chaise in that set is higher backed (Though it is possible it could be scaled down on the y-axis)
...close (at least the colour), however the design of the arm and how it meats the cushion is different
Wow, I didn't know that this one would be so trcikcy to track down! Thanks everyone for the alternative suggestions.
This one is quite similar, with a few shaders you could get it pretty close I think: https://sites.google.com/site/mcasualsdazscripts8/mcjloungesofa2017
There's also this one: https://www.daz3d.com/toon-egypt-ii
Not the chair, but similar:
https://www.daz3d.com/interior-furniture-03
check this https://www.daz3d.com/dforce-loincloth-collection-for-genesis-8-females
Check the RDNA stuff too. There was a fair amount of Egyptian stuff released alongside of one of Littlefox's Egyptian outfits for V4 fairly late in the site's history, before DAZ aquired it.
The one in the promo almost certainly has been given some shaders, as well.
Very similar: https://www.daz3d.com/fg-gothic-hall
Another contender: https://www.daz3d.com/boudoir-photo-studio-and-lights
currently the texture add-on is up for free... https://www.daz3d.com/boudoir-photo-studio-add-on
@VLEREN
The clothes (see FirstBastion's answer) have been used with different shaders:
https://www.daz3d.com/ultra-shaders-egyptian-fabrics
These shaders give you material and patterns to mix and match.
This is from
https://www.daz3d.com/egyptian-outfit-for-genesis-3-male-s
Shoes are from https://www.daz3d.com/desert-watcher-outfit-for-genesis-8-female-s
All that information can be found on the bottom of the product page mentioned by the OP.
i THINK that mding is saying that the women are wearing autofit male clothing
A little practical /technical information.
A shader is generic and can be used on any clothing.
A material is designed for a specific piece of clothing. So you cannot use a material on another piece of clothing. (If you know your way around in an image editing program, you might be able to match the material to another piece of colthing. But it can be rather fiddly, and I would not recommend it).
One thing when using shaders, is that you only can apply a shader to a whole surface, so if the PA of the clothing has created more surfaces, you will have a much easier job (but often you don't know the surface layout unless you own it. Some PAs add an image that shows the surface layout, but that is in my view rather few. You can add a new surface yourself, with some work)
The only similar female clothing i found is
https://www.daz3d.com/samira-outfit-for-genesis-3-female-s
But i thought ths one mentioned above was closer:
It could also be a combination of both...
Shaders can be used on every piece of clothing, that way you can adapt the look and feel of your 3D clothing to your liking.
Depending on what figure you want to use you may need clothing converters.
Again to avoid misunderstandings, i THINK:
Dress and Bra from
Shoes from
"belt" from
And shaders from
no guarantees, it is your decision...
No, at least one item, the top, is definitely from the exact item FirstBastion linked:
Possibly with this skirt, also included in that product:
Although the G3M outfit mding linked above does look like a better match.
