Render Problem
When I render in DAZ Studio 4.20 (Latest Update) I keep getting this arifact! Any suggestions? Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,449
    What is that?
  • GranvilleGranville Posts: 702
    I also have been getting artifacts with semi transparent areas. Especially in this product. When I submitted it, I was a bug.
    https://www.daz3d.com/cloudscape-creator--sky-cover-for-iray
    Which product are you using? could you give us a larger view. If it uses the normal iray settings, I think you could work with cutout opacity to make it 100% (or 0%) Then you would need to add oldschool backlighting to create any kind of glow. The product above has a custom shader so I don't know how to access cutout opacity. Maybe yours is a standard Iray shader.
    Will you let us know what find?
  • Solved. It was a prop designed for a different figure than I am using. When auto parented to my figure it distorted the prop as the camera moved closer it gave out this odd artifact when rendered! Cheers
