Daz crashing after new GPU install.
Hey, so I recently decided to update my graphics card to an RTX 3090 from a GTX 1080ti. After I installed the new card I spent night 1 rendering and it went find and rendered something like 52 renders in a night. Night 2 however, daz crashed after rendering 4-5 renders. I don't get a crash report though, daz just closes. I was told up update my graphics drives which I did and I was also told to update my daz to 4.20 which I also did. After updating my daz to 4.20 I could batch render again, however, all my ghost lights stopped working which I found was a common issue apparently. So I've now downgraded back to 4.16 which is what I was on before and my ghost lights have started working again, however, batch rendering and rendering in general has stopped working. Even if I just click the render button daz will start the render but like 20 seconds later just close on it's own.
Any idea what the issue could be? I'm not sure where I can upload a crash report but here is a snippet of the end.
2022-05-13 09:08:41.839 Starting NVIDIA Iray...
2022-05-13 09:08:41.848 Iray [INFO] - CLUSTR:NETWORK ::   0.1   CLUSTR net  info : Networking is switched off.
2022-05-13 09:08:41.851 Iray [INFO] - CT:IMAGE ::   1.1   CT     img  info : Plugin "ct" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - DDS:IMAGE ::   1.1   DDS    img  info : Plugin "dds" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_bmp" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_cut" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_dds" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_exr" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_faxg3" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_gif" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_hdr" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_ico" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_iff" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.851 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_j2k" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_jng" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_jp2" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_jpg" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_jxr" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_koala" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_lbm" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_pbm" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_pcd" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_pfm" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_pict" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_png" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_psd" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_ras" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_sgi" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_targa" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_tiff" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_wbmp" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_webp" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.852 Iray [INFO] - FREIMG:IMAGE ::   1.1   FREIMG img  info : Plugin "fi_xpm" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.937 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : NVIDIA display driver version: 512.59
2022-05-13 09:08:41.937 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Your NVIDIA driver supports CUDA version up to 11.6; iray requires CUDA version 11.0; all is good.
2022-05-13 09:08:41.937 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): compute capability 8.6 will be run as 8.0 by this version of iray.
2022-05-13 09:08:41.937 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Please look for an update with your software provider to render at optimal performance.
2022-05-13 09:08:41.939 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Using iray plugin version 5.1, build 334300.9558 n, 27 Mar 2021, nt-x86-64-vc14.
2022-05-13 09:08:41.998 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): compute capability 8.6, 24.000 GiB total, 22.904 GiB available, display attached
2022-05-13 09:08:41.999 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : iray photoreal CPU fallback is enabled.
2022-05-13 09:08:41.999 Iray [VERBOSE] - IRAY:RENDER ::   1.1   IRAY   rend stat : Environment cache size capacity: 5.
2022-05-13 09:08:41.999 Iray [INFO] - BLEND:RENDER ::   1.1   BLEND  rend info : Plugin "blend render" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.999 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_cloud" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.999 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "irt_cloud" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.999 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "nitro_cloud" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:41.999 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iq_irt_cloud" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - IRT:RENDER ::   1.1   IRT    rend info : Plugin "irt" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - EIAXF:IO ::   1.1   EIAXF  io   info : Plugin "axf importer" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - ICB:IO ::   1.1   ICB    io   info : Plugin "cb_importer" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_snapshot" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - IRAY_CLOUD_SERVER:NETWORK ::   1.1   IRAY_C net  info : Plugin "iray_bridge_server" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - EEMI:IO ::   1.1   EEMI   io   info : Plugin ".mi exporter" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.000 Iray [INFO] - EIMI:IO ::   1.1   EIMI   io   info : Plugin ".mi importer" (build 334300.9558, 27 Mar 2021) initialized
2022-05-13 09:08:42.001 NVIDIA Iray GPUs:
2022-05-13 09:08:42.001 GPU: 1 - NVIDIA GeForce RTX 3090
2022-05-13 09:08:42.001 Memory Size: 23.9 GB
2022-05-13 09:08:42.001 Clock Rate: 1725000 kHz
2022-05-13 09:08:42.001 Multi Processor Count: 82
2022-05-13 09:08:42.001 CUDA Device ID: 0
2022-05-13 09:08:42.001 CUDA Compute Capability: 8.6
2022-05-13 09:08:42.001 PCI Bus ID: 1
2022-05-13 09:08:42.001 PCI Device ID: 0
2022-05-13 09:08:42.001 TCC Mode: disabled
2022-05-13 09:08:42.001 Display: attached
2022-05-13 09:08:42.001 NVIDIA Iray Scheduling Configuration:
2022-05-13 09:08:42.001 CPU Load Limit: 16
2022-05-13 09:08:42.001 CPU Thread Affinity: disabled
2022-05-13 09:08:42.001 GPU Load Limit: 1
2022-05-13 09:08:42.158 Total class factories: 2078
2022-05-13 09:08:42.159 Creating Script Engine...
2022-05-13 09:08:42.168 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2022-05-13 09:08:42.169 3D mouse support library could not be loaded.
2022-05-13 09:08:42.169 Creating Main Window...
2022-05-13 09:08:42.170 Creating Viewport Manager...
2022-05-13 09:08:42.197 Successfully created OpenGL viewport for Viewport1.
2022-05-13 09:08:42.254 Successfully created OpenGL viewport for Viewport2.
2022-05-13 09:08:42.291 Successfully created OpenGL viewport for Viewport3.
2022-05-13 09:08:42.328 Successfully created OpenGL viewport for Viewport4.
2022-05-13 09:08:42.371 Creating Action Manager...
2022-05-13 09:08:42.376 Creating Pane Manager...
2022-05-13 09:08:42.465 Successfully created OpenGL viewport for AuxViewportView.
2022-05-13 09:08:42.895 Updated metadata for 0 of 1 items.
2022-05-13 09:08:43.031 Executing startup script...
2022-05-13 09:08:43.077 Started in: C:/Users/CellStudios/Desktop/DAZ Studio_4.5_(64-Bit)/DAZ 3D/DAZStudio4 Public Build
2022-05-13 09:08:43.077 DAZ Studio Started
2022-05-13 09:08:43.077 Creating Pixel Buffer
2022-05-13 09:08:43.097 Pixel buffer - Width: 1024 Height: 1024
2022-05-13 09:08:43.097 Compiling OpenGL Shader...
2022-05-13 09:08:43.101 Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
2022-05-13 09:08:43.486 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
2022-05-13 09:08:43.486 Metadata update succeeded.
Post edited by zillaboom_6832aa1fb9 on
  • Richard HaseltineRichard Haseltine Posts: 108,982
    That's not even getting as far as loading the content you want to render. You should be able to attach the log or the whole crash report to your post - click Attach a file below the text box, then the Browse button.
