Adding to Cart…
I checked here in NZ and a 3080 is available (yes, available to click and collect) for NZ$1600. That is still high compared to approx NZ$1000 it was expected to be on release.
The other issue is the new cards may not fit in my PC case.
I think the best GPU value right now is the 1080 ti. You can usually get one on Ebay for around 400-450, and it has 11 gig of VRAM. As for how many cards you can fit in a case, it depends on the case and the cards. You also need ample pwoer for it to run. I have two rigs, one of which has three cards and although there is a fourth slot, none of my cards fit into it. My other rig now has two cards, but it used to have three. Both cases are full tower. It would be hard to get three cards into anything smaller. Also, a smaller case may heat up too much and caused the render to fail. For two cards, you can probably aqueeze that into a mid sized case.
When I built my rig GPU based rendering was just starting which was why I went for a twin Xeon build with the GPU being an after thought.
DOH!
I'm waiting for the Apple Mac M2 and the new integral GPU units. There is a reson why NVIDEA bought ARM.
Okay, finally updated from my 1060 6G to a 3060 with 12G.
Ran my largest scene no probs although I was shocked to find that the scene was using up over 10G of my GPU's 12G of Vram.
I'm just glad GPU prices are back to sane sizes;)
Learn to live without fear or worries and buy a Quadro 8k....nuff said
I buy what I can aford;)
Selling a kidney is always an option
They should be able to 3d print one by now.
Weird, I loaded another scene that was a bit high in the Vram usage 5.4 to 5.8 G of Vram using thte 1060.
But when I render the same scene (same machine) but now with the 3060 it uses only 4.1 G of Vram?
For some reason some scenes no longer use as much Vram when rendering?
Both are using default Iray settings and same scene file & machine, only the GPU is changed.
Rendering Iray on a GTX card uses about a gigabyte more VRAM than rendering the same scene on an RTX card due to required emulation of RTX functions.
More ram for me.
Woohoo
Well its been a few years and my old 3060 while still usable is groaning render time wiseand tthe 5xxx range is finally been out for a bit.
Does anyone have or know of any any GPU Iray render time comparisions?
Its time for another upgrade.
