Air tank for vintage-scuba-gear-for-genesis-8-f goes upside down when g8f is posed
VicSVicS Posts: 1,273
edited May 2022 in Daz Studio Discussion
the tank comes in properly when g8f is in the zero postion but when posed swimming downward for example the take either stays where it is or goes into upside down position
when she is already swimming downward and tank is clicked to fit on her the tank comes in upside down, has anyone else had this issue and know a fix for it?
I did try to change the parent thinking that was the problem but it didn't help,
thank you
https://www.daz3d.com/vintage-scuba-gear-for-genesis-8-females
Post edited by VicS on
  • Richard HaseltineRichard Haseltine Posts: 108,534
    The tank should not be fitted, it should be parented to the Harness figure - via a Rigid Follow Node. Is that how it is for you?
  • VicSVicS Posts: 1,273
    THe harness tank and hose all go upside down,
    this is how it loads, (this loaded it seperate not as the full suit but same result)
    848 x 1488 - 379K
    It worked for me with the included swimming pose - does that pose cause the issue for you?
    Yes it was all with that pose from an underwater set-all 4 similar poses do the same mistake, all the other poses work normal-thanks Richard
    See if you can spot any differences - do the bad poses use a different node (figure vs hip) to rotate the figure, for example?
    Ok thanks again  Richard
