Why are the 3d models doing this
Why are the 3d models doing this Genesis 8.0 and 8.1 models i have idea why it just started doing this i did a full reinstall of Daz3D and now it started doing this.
Please Help if you can
  • SyczBearSyczBear Posts: 21
    edited May 2022
    753 x 818 - 43K
    603 x 882 - 35K
    537 x 397 - 12K
    587 x 903 - 39K
    Post edited by SyczBear on
  • frank0314frank0314 Posts: 14,757
    What version of Daz Studio are you using and how are you installing it?
  • benniewoodellbenniewoodell Posts: 2,000
    The only thing I can think of to try is to check and make sure that the character has it's rotation limits turned on or not. Otherwise, I have no idea.
  • FenixPhoenixFenixPhoenix Posts: 3,186
    @SyczBear, make sure you haven't installed anything through the DAZ Connect as well (meaning when in smart content, you click on "install") as that would create a copy of the data folder in the "cloud" (another directory in your computer). If you didn, you'll need to uninstall from there as well. Also, make sure you don't have any other 3rd party directory linked to your DAZ studio so you can check which character/morph created the problem.
  • FirstBastionFirstBastion Posts: 8,050
    edited May 2022
    SyczBear said:
    I have 7044 models from daz3d i've been with dasz3d from the start. nothing for free unless it was from them i don't know why it started doing this after i reinstall  everything,
     I'm with you, I generally only install Daz content because I had that problem happen in the past  and learned the lesson the hard way. If it is all Daz installed content then Fenix suggestion to see if there is some overlap happening between DIM installed and Daz Connect installed looks like a plan. Hope you figure it out.
  • Richard HaseltineRichard Haseltine Posts: 108,884
    Is this happening with just the base figure, or only with certain characters for the abse figure? Is nore than one base (Genesis #) affected?
