Problem with Transfer Utility
Hello,
I have created the clothes in Clo3d and exported as Obj, when I use the Transfer Used to fix the clothes to the avatar I get this error, I have tried many configurations, but it is not solved. Does anyone know what the error is?
Thanks a lot.
  • After much research I have been able to fix it with Smoothing and Collisions interactions ... laugh
  • Make sure you are working around the base figure, not a morph (or if you must have a morphed figure, in Transfer Utility set Current Shape to the morph used and then in the options enable Reverse Source Shape from Target).
  • iehaiel2iehaiel2 Posts: 0
    edited May 2022
    thank you very much friend, I spent months looking for a way to adapt the clothes I made in zbrush to my already modified characters is DAZ
  • Thank You Richard! Wow, so many learning curves here, I would not have figured this out without your help.
