Weird geoshell issue
I have this weird issue where a geoshell stopped loading textures when I am under the render tab. In fact, the surfaces window doesn't even show the special sections created by the script for the product any longer. This is a third party product (Futalicious and dicktator genitalia) and I have posted over in renderotica, but just wondering if anyone else has had this problem with any other products that use geoshell. Everything is fine when I am under the actor, props tab, and I can even render correctly from under that tab. Just curious if anyone has any idea why it would suddenly mess up under the render tab and not the actors tab. Maybe some setting I can fix or something. Thanks
Which tools are active in the two tabs?
Thanks. That was it. I got sloppy and the weight map selected in the tools settings
