Some new (old) items
These were available at ShareCG but have been removed. The old files did not conform to the new standard I use. So I redid the original obj files and imported them in to blender. They were converted to quads and then exported as new obj, fbx, and blend files. I also did a uv image and a promo image of each. These are available in the part 2 file. I created a new set of DAZ prop files for each item and saved these files under a myLibrary location (available in the part 1 file). You may or may not want to download both parts (or either part) depending on if you got them before. If you do download them, please delete any old versions of the files as some of the names changed and you could wind up with two copies.
Not sure when they will be approved for download, but expect they should be available in the next couple of days.
You can find the here: https://www.renderosity.com/users/BronzeDragon2001/freestuff
  • Sky77Sky77 Posts: 820
    These look amazing!  Thanks for sharing!  laugh
