Help: Strange green artifacts on the render
Hello,
after rendering with Iray (MDL) engine I get some green artifacts on the black materials. I provided an example in the attachement.
Anyone has any idea what it is and how to get rid of it?
Thanks for help in advance.
  • WolandWoland Posts: 0
    I'll add it happens only if the meterial is black. It is also visible in preview if I set to Iray. Tried to play with lighting settings, but nothing has helped yet.
    There are several surface settings to check through: glossy, metallic, reflective etc. both for the glove/hand and/or the surfaces throwing lights around.
  • cgidesigncgidesign Posts: 442
    Depending on material and settings "top coat" in surfaces can cause this.
    Or maybe there is some "green" in your surrounding that gets reflected on the gloves?
     Decreasing "metallic" setting on the glove has helped. I don't understand it though, why maxing it (metallic setting) out causes this green noise?
