dress problem
REIVAXREIVAX Posts: 71
edited May 2022 in Hexagon Discussion
Hello all
how i can do the bottom of jacket. when i move points hexagon crash
Post edited by REIVAX on
    REIVAX said:
    Hello all
    Is the seam really open in the centre? The shield part looks like it has a seam, but the skirt part doesn't.
    You want the mesh under the centre shield deleted, then select some points along each side [one side at a time] and with soft selection set to a small value, move the mesh over to make the flaps.
    If moving a point is making Hexagon crash, you have done something with the entire mesh that Hexagon doesn't like. A wireframe view would provide more information. Also, is the entire thing "one group" or several? If several, only select one group when working on it.
  • REIVAXREIVAX Posts: 71
    edited May 2022
    Hello Catherine
    Thanks i make one try.Almost correct
    1380 x 863 - 112K
    edited May 2022
    sample ty again
    565 x 800 - 955K
    REIVAX said:
    sample ty again
    That is a cute challenging outfit. The skirt all around would need to be its own item. End result is one jacket and one skirt.
    The belt and barrel purse? would also be separate items.
    To make the frills -- solid layer(s) of mesh. Use textures to give the appearance of lace.
