DAZ Studio File Paths
Correct me if I am wrong, but the DS File Paths here merely indicate where DS is installed, and not where the file contents will be/are installed?
     The Content Path should be set to the location where you are installing D/S content, this isn't likely in your Downloads folder.
    The DAZ Studio 4.x files path should be to the location which holds the .exe for D/S.
    Some content such as shaders have to install some files in the applications folders/sub-folders.  Advanced Spotlight seems like it is one such content item.
