Weight Map Brush - what does Locking and Selection Analasys do ?
cgidesigncgidesign Posts: 442
What are those two panels in the weight map tool intended for?
Post edited by cgidesign on
  • Richard HaseltineRichard Haseltine Posts: 108,546
    Locking protects certain maps, Scene Analysis lets you see the actual weight values for selected vertices (useful, for example, when trying to weight a solid item uniformly)
  • cgidesigncgidesign Posts: 442
    So, locked maps do not react to weigth painting anymore but keep the value they had before they got locked?
    For the locked bones, I believe - so if you lock the thighs any weight you remove from the shins would go straight to the pelvis/hip, for example.
    Ok, did not know that. Could be beneficial in some cases. Thanks.
