Nvidia driver preference? Game Ready or Studio?
Is there a difference when using DS?
  • Richard HaseltineRichard Haseltine Posts: 109,466
    nVidia certainly recommends using the Studio drivers, the concern is that the Game-ready drivers are bleeding-edge as they are cosntantly being tweaked to support new games and so more likely to throw up issues. If you have a Game ready driver that works there is no reason not to use it, just be aware that the risks are higher.
  • prixatprixat Posts: 1,617
    RTX3060 has no problems with Game Ready Drivers.
    RTX3090 and up, seem to require Studio drivers.
    ...for the GPUs inbetween you'll have to experiment.
  • RL_MediaRL_Media Posts: 339
    I stick with the studio, unless I need a game ready driver to fix an issue on a game I am playing is how I do it.
  • roni190roni190 Posts: 40
    I've had times where the newest Game Ready drivers would not allow IRay renders to even start.... Studio is the only real choice.
  • M-CM-C Posts: 104
    For me the Game Ready drivers manage to crash the iray preview mode if I leave it activated while fiddeling with the scene for a while.
    That never happend with Studio Drivers.
  • AabacusAabacus Posts: 407
    Not OP but an interested party who apparently is an idiot...
    Where might one procure these Studio drivers?
    edited May 2022
    When you get to the nVidia download page you get a choice:
    1267 x 761 - 392K
    Post edited by prixat on
    That explains it...I was using their tray widget to update.
  • reelyorreelyor Posts: 237
    Studio drivers sem to render faster in IRAY.
    I mistakenly installed Gaming, and usual render was taking way to long. So I changed to studio driver and got much quicker results.
  • nakamuram002nakamuram002 Posts: 818
    I have had good results using the Gaming drivers.  My gaming is done in real-time, my rendering is done in the back ground as I browse the net and watch videos.
    Do you have any numbers for that?
  • Anarkia333Anarkia333 Posts: 104
    edited May 2022
    use Studio Drivers all time for work, make for that...
    Game ready is make for game, no stable, new fonction and bug everywhere for works with Soft.... xD
    Post edited by Anarkia333 on
  • from my own expirence both drivers work however game ready drivers can sometimes be a bit unstable.
    So far as i can tell this is because game ready may somtimes have special corner cases that will be fixed the the next version.
    These corner cases are possibly because the game ready drivers are optimized towards a combination of general computing and gaming.
    Some of what ive expirenced with game ready:
       out of control memory use by daz (BSOD)
       unreliable performance
    TLDR: using game ready with daz is like using a stepladder for a bridge while using studio is like using the same step ladder but also adding planks of wood to step across.
  • drawfleshdrawflesh Posts: 17
    edited February 23
    Running DAZ3D 4.24 on a i7 11th gen, 64GB and RTX3070 8GB laptop. The studio drivers have given me more than my fair share of crashes (and sluggish performance in rendering), while the game ready driver has not given me any crashes and also seems to use the CPU/GPU rendering better. It doesn't fall back but  runs hybrid. In all, I would say: Game Ready Drivers.
    Only addition: I have a Lenovo Legion which seems to take quite a bit of power from the GPU if I leave the USB-C display connected. Without it, it will perform about 20-30% faster.
    Post edited by drawflesh on
  • IceDragonArtIceDragonArt Posts: 12,966
    I have a 5060 card, studio driver works much better than the game ready driver and doesn't cause any performance issue with my gaming either.  Was having all kinds of issues until I switched over to studio drivers
