Genesis 2 Female Essentials - Smart Content not categorized correctly
Hi!
I have installed G2 Female Starter Essentials via DIM to the following folder:
..\Documents\Daz3d\V6\..........
If I open a new scene without anything selected and go to the Smart Content Pane\Figures\Genesis 2 Starter Essentials, I am shown everything in the whole entire package, lights, materials, props, etc. (see attached image)
I would think that the smart content pane would be smart enough to show me ONLY Figures when I select the figures category.
Is there something wrong or is this the way it is supposed to be?
I've also attached an image of my V6 directory structure if the 'issue' may be there.
Thanks!
Jason
    You are selecting 'Products', and in the box at the top, you will see All, No Category and Default.
    Select Default, then Figures > People > etc etc to follow the list down.
    If you want to see all figures in your library, select 'Files' (instead of Products), then Default > Figures.
  • j_koko2_f2572d4e05j_koko2_f2572d4e05 Posts: 17
    Thanks JimmyC,
    It all makes sense now!
    Jason
