• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Daz hair that works in C4D?
brandongnetworkingbrandongnetworking Posts: 0
April 2022 in Cinema 4D Discussion
I'm struggling to find a hair that properly exports to C4d. I'm spending hours trying to get the Daz hair to render properly in C4d. The hair never properly translates into the  ALPHA channel. The hair is always in blocky stips. can anyone please share some hair products from the Daz store that are guaranteed to render in C4D?
  • pixel8tryxpixel8tryx Posts: 7
    April 2022
    All hair should eventually work in C4D.  I’m used to exporting OBJs and FBXs, so I’ve always had to go find my own textures.  Transmapped hair might need the alphas loaded.  If you’re using the bridge you should get a lot of the other maps.  Most maps are quite easy to find but hair alphas are sometimes shared among different styles or at least no well-labelled.
    What I do is usually keep DAZ Studio open so I can look at the hair material there to find the alpha.  It might be under ‘opacity’ or ‘cutout’.   And if you can’t find it, some hair styles use similar alphas, so try one from some other style.  I almost never use their initial hair color anyway.
    Also… if you HAVE alphas and you’re STILL getting more chunkiness than you think you should: check the Ray Depth in your C4D Render Options.  Depending on the hair style, you can end up with tons of overlapping alphas, which to C4D are just as ‘bad’ as transparency.  I have mine cut back to 10 for data viz stuff, but I have to up to 30+ for some DAZ hair.
    Or… don’t want to mess with trans maps?  Use strand-based hair.  Just make sure that you first turn Generate and Preview PR hairs ON, and then set Viewport Line Tesselation to 3 if you can handle a lot of polys, or a worst 1.  It may look like a boatload of polygons… but I’ve had some render way faster than any transmapped hair.
  • GordigGordig Posts: 10,799
    April 2022
    The problem isn't the hair, it's the way materials transfer across programs and render engines. As stated above, you can just plug the cutout opacity maps into the alpha slot in your C4D materials.
    April 2022
    You can also export dForce hair as splines, allowing you to use C4D's hair system.
  • 364888487364888487 Posts: 7
    April 2022
    戈迪格说:
    pixel8tryx说:
    或者……不想弄乱跨地图?使用基于股线的头发。只要确保你首先打开 Generate and Preview PR hairs ON,然后将 Viewport Line Tesselation 设置为 3,如果你可以处理很多多边形,或者最差的 1。它可能看起来像一大堆多边形......但我有有些渲染方式比任何转映射的头发都要快。
    您还可以将 dForce 头发导出为样条线,允许您使用 C4D 的头发系统。
    dForce ?
    April 2022
    Yes!  I forgot about that!  I did Underbelly's arm hair on Dasan I think.  I either completely forgot to turn on preview or something went wrong, but all I got was splines, so I ran with it.  It didn't look all that bad, but then I didn't give him a close up.  But I didn't get very far trying to make a Newfoundland from... the wolf?  Something for which I have hair splines.  I think it's going to take more individual follicles than I was willing to deal with... then I found out the dog in question didn't look much like a newfie anyway, so I gave up.  I did export the dog hair as polys initially, but I'm often underwhelmed with animal hair.  By the time it reaches C4D it's usually sparse in spots, particularly around the most important part for me - the face. There were a lot more facial splines or... I think C4D was using my length parameter and ignoring the spline length.  So it made up for the super, super short face hair.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
