Swimsuit Materials Expansion Pack
43 assorted DAZ Studio Iray "flood fill" type materials intended for any model with the surface group names "cloth" and "trim" - all of my swimwear models follow this convention, so these materials will work on any of them. All of them are saved with the UV map parameter excluded, so they are not linked to any specific model. If you happen to have older versions of any of these files, it's OK to overwrite them with the ones included in this version. Several new colors of the existing cotton and silk shaders have been added, as well as a lot of lamé color varieties and a set of latex/pleather shaders too!
NB: Most of these materials make heavy use of REFLECTION, and if you don't have anything to reflect in your scene then they may not look very interesting. All of the promotional renders were done just using the DAZ cyclorama with a couple of emissive lights above the models to provoke some reflections - if you want any highlights or reflections to show on the models, you may need to add some lights by hand. THIS IS VERY DEPENDENT ON YOUR LIGHTING SETUP. Refer to the Iray documentation and/or DAZ tutorial info for more information.
ShareCG: https://sharecg.com/v/98959/view/21/DAZ-Studio/Swimsuits-material-expansion-pack
Google Drive: https://drive.google.com/drive/folders/1KQ60nCRhTiPkQafBL2h-0zXhUssB4qSk?usp=sharing
have fun :)
I realize I only released the suit revamp yesterday but this package has 21 new material options that weren't included, so you should still get this too! enjoy :)
Thanks, just wonderful
Phwee. Thank'ee kindly.
Regards,
Richard
