xFrog trees Freebies
2»
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,578
    I am painfully getting 2 maybe 3 every other hour and at least one of them the unzip will fail
  • Charlie JudgeCharlie Judge Posts: 13,409
    Thanks Sean. I'm not sure what the problem is but I tried downloading the bad files several times and always got the same result. I submitted a ticket to X-Frog but if you guys are getting the ones I mentioned OK then the problem may be on my end.
    Charlie
    yes work next time ............ sometimes .............. if I can download it
    edited January 2015
    Well, after trying until I had tried so much that I got an 'Expired Download' message I simply reordered them and now I am getting valid files.
    Charlie
    Post edited by Charlie Judge on
  • GussNemoGussNemo Posts: 1,855
    Thanks for the link, mermaid. It's been some time since I downloaded their trees.
    Because I've had problems with 3DS objects in the past, I stick to .obj files if they're available.
    Also, if you don't know, you'll have to fiddle with the leaves in order to get regular looking leaves. Horo has information on his site which explains what needs done to fix x-frog leaves.
  • mermaid010mermaid010 Posts: 6,128
    I could only download two files at a time but once both were downloaded, I did not have problems downloading two more. I have now downloaded all the files and unzipped them. The next task is to add them to the Obj. Library
    Guss - I also did not download xFrog trees for a long time. All these have obj. models.
