Iron Scale Armor Bundle incomplete? (SOLVED)
Lee MoonLee Moon Posts: 935
edited April 2022 in The Commons
Hi all!
If anyone has purchased the Iron Scale Armor bundle, did you find any of the items?  I downloaded the bundle (it was a single download file of 6.8MB if I recall - which seems too small.). There are no files showing up in my Smart Content for any of the items in the bundle.  When I locate the folders on my drive and manually drag the outfit file (Iron Scale Armor !Outfit.duf), I get a bunch of errors and a bunch of blocks loaded onto Kento.
I'm not sure what I'm doing wrong or where to locate the non-smart content to properly load the outfit pieces.
Very grateful for any assistance. :)
Lee
Post edited by Lee Moon on
    I don't have it, but don't rely on smart content. Go to the content library and see if it is there. The location should be “People:Genesis 8 Male:Clothing:Iron Scale Armor”
  • Lee MoonLee Moon Posts: 935
    edited April 2022
    Thanks FSMCDesigns!
    I submitted a ticket after looking at the Product ReadMe wiki.  Most of the folders are not showing up.  I had a feeling there was going to be trouble when I saw only one install file in DIM for the entire bundle.  The Future Formal Outfit Bundle  that I also purchased, showed multiple install files in DIM, and that product bundle shows folders installed where they should be on my system (and show up properly in Smart Content.)
    The data folders are all missing for Iron Scale Armor.
    Thanks again for the suggestion and taking the time to help! :)
    Lee
  • MelanieLMelanieL Posts: 7,867
    I don;t have it either, but I noticed this morning that the store page for the bundle is not showing the component parts (six of them) as part of the bundle. I think this is probably your problem. I suggest posting about it in the main Sales forum thread - you may need to raise a support ticket too, but it would be helpful to flag it up for other people there.
    Thank you, MelanieL!
    I've just added a post to the main Sales Forum thread you referenced.  I appreciate the help very much!
    Lee
  • KainjyKainjy Posts: 913
    It could be a Daz/DIM problem. Some product (usually recent updated) aren't installed. To check it you must: 1- Open Daz Studio 2- Inside Daz Studio Login with your user and password 3- into Smart Content Tab, click on Avaiable (lower panel part). If a product isn't installed you'll have a grey miniature 4- Right click on miniature and select Install
    Thank you, Kainjy!  It's a store problem (most likely) since DIM only showed one install file (I think for loading the entire outfit at once, dforce presets(?), and texture files) and the store page for the bundle doesn't show all the separate items either.
    As MelanieL pointed out the store isn't showing the items in the bundle pack either.  I think I'll let DAZ sort it out properly and give it a go again when they've fixed things. :)
    Thank you for the detailed instructions on a possible user remedy!!
    Lee
  • Richard HaseltineRichard Haseltine Posts: 111,382
    As MelanieL says, it looks as if the sub-parts are not associated with the bundle. I will flag this up for fixing.
    Thank you so very much, Richard and MelanieL!
    I appreciate all the help. :)
    Lee
    I got a response to yesterday's trouble ticket acknowledging the issue.  Got back from lunch a short time ago with another response saying the issue was fixed.  And it was! :)
    Support saw the same issue I was seeing and got it taken care of.  Bravo!!
    Very happy that this was looked after in a very timely manner!  Many thanks go out to all who assisted in this thread and DAZ staff who worked on the problem.
    Thank you all. :)
    Lee
  • Write IdeaWrite Idea Posts: 490
    I'm having the same problem.  Read on the boards last night that there was a ticket submitted for it.
    Didn't realize I had to submit my own for it.  Now I have to wait all weekend in order to use the product.  frown
    edited April 2022
    Try restarting DIM, if that's your installation method.  That's what Support had me do after they fixed things on the store side.  They also reset my downloads, so that *might* be needed in your case as well, which will likely require a ticket.  Don't know if uninstalling the original incomplete installation and then refreshing the downloads will get all the files to show up or not.
    Lee
    Lee
    I download all my stuff through Smart Content (I can never rememeber the correct name for it, but it isn't DAZ Install Manager or DAZCentral).  The past work around for that was to uninstall the item, Update Metadata, then close DAZ Studio and redownload said product.  It would work in the past, but not now.
    I can't even download it manually in my product library.
    Thanks though, Lee!
    Lee
    Thanks though, Lee!
    Have you tried logging out and back in, or restarting Daz Studio?
