Adding to Cart…
The boar includes a riding pose, and several different poses for the boar only.
There is a set of secondary poses, but for me, they don't work too well. The boar poses on the ground, but my character flies up in the air high above the character. I am not sure what I'm doing wrong.
Thanks for the info. Maybe I can cobble a different riding pose that will work OK.
I tested out the Boar Rage Poses. They work okay on Genesis 8.1 and the battle Boar from a zeroed position. I think the rider pose I used initially must've had some baked in translation, since every pose I used after, had the rider in the wrong place. But if you start from zero it works nicely.
Does anybody know what hair this is?
Does anyone know where this hood can be found?
Don't know about the hair, but the hood is from this: https://www.daz3d.com/dystopian-hd-outfit-for-genesis-8-and-81-males with this texture set: https://www.daz3d.com/dystopian-hd-outfit-textures-expansion
If this helps, the DForce Hair on the Battle Boar can be deleted if you don't want to use it. And it can be loaded back onto the Battle Boar if you change your mind. I created 8 poses for the Battle Boar and a return to default pose. There is a Pose for a Genesis 8 and 8.1 Female in my set because that was something I wanted to include. The other packs have the male poses covered. Any figure once you pose them can be parented to the saddle and won't fly into the air no matter how high the Battle Boar jumps. I hope this is helpful, it's important to have the answers when folks are asking questions.
Thanks
The AntMan
Thanks, @zombietaggerung! I bought that, but I haven't broken it out yet. I'm glad it looks that good.
Can't find that exact one but here are a number of similar options that could work:
