Can't locate .dsx files created by DAZ 3D DB Editor
ExtremeAlphaExtremeAlpha Posts: 82
Hello
I used the Content DB Editor to add custom metadata to some products I use in DAZ Studio. According to the information in the DAZ 3D Document Center it shows the Content DB Editor creating the file automatically. That option is not available in DAZ Studio 4.7 Pro. I can't locate the .dsx file for the product anywhere. I included a screen shot to show you what I'm talking about.
Where can I locate the .dsx files created by Content DB Editor. I looked in Runtime > Support the files don't show up there. I need to add a thumbnail to the product, but I need to locate the .dsx file before I can do that.
I went to the forum and knowledge base and overtime I get referred back to naming the thumbnail the sane as the .dsx file and place it in the same folder. The problem is that I can't find the folder with the .dsx files created by DAZ 3D DB Editor.
The url to the DAZ 3D Document I used is: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/packaging/tutorials/adding_metadata/start
Thanks
Tony Coe
  • IceCrMnIceCrMn Posts: 2,322
    from your screen shot it looks like the Content DB editor in the tutorial is the one that is launched from the Content Library while "Products" is selected.Select your products' main folder in the Content Library under "Products" and see if you get the one that is showing in your screen shot.
    1920 x 1080 - 430K
  • ExtremeAlphaExtremeAlpha Posts: 82
    Thank you !!!
    When I went to the product directory I was able to find the path.
