Genesis 2 Seams
Are the genesis models meant to have these faint seams between the hip and the leg, as well as the torso and shoulders? Recently noticed this with Genesis 2 female and male, along with genesis 1. I've attached pictures, the first two are the shoulder and leg areas in the viewport, and the last two are renders of those areas. The seams are more difficult to spot in the renders, but they are there. The model is un-modified, and the shading rate in the renders is set to 0.15.
Post edited by Vertigo789 on
I remember on a video that seams tend to disappear with good lighting and a Shading Rate no higher than 0.10.
I guess if you are rendering closeups of the anatomy it's a problem since i can barely notice them. Could also depend on the texture set you are using and who developed them...
