Loading scenes with textures already applied... not what I need
Panzer EmeraldPanzer Emerald Posts: 727
I have a really frustrating problem.
Earlier today, and long before that, whenever I'd load up a file, character, prop, w/e in DAZ, it would always show up as grey/white/uncolored... otherwise without texture to it. This is pretty much what I'm talking about, if a visual helps.
All of a sudden this afternoon, I don't know if it's because of an update or what, every single scene I try to load now automatically loads with the texture already on it in the Posing/Shaping submenu, except for hair for some inexplicable reason. Like somehow diffiusing/texture stuff is automatically turned on.
I primarily use DAZ as reference for my artwork/design stuff, and having it all be that unified grey-ish color was helpful when it came to shading (much less having a general idea of how things would look from weird angles), and not having so much stuff distracting from it. This is just a hot mess. I tried doing a complete uninstall-then-reinstall of DAZ, but that didn't do a single thing. (Eh, it was overdue anyways, my files were getting unruly)
I'm at a complete loss for what to do. Is there a way I can just switch it off in the Posing/Shaping menu like it was before, or am I plum out of luck?
Thank you.
Post edited by Panzer Emerald on
  • KhoryKhory Posts: 3,854
    For most products loading with textures is expected/functioning properly. You can always select all the surfaces in the scene and use the base shader to make them all white.
  • fixmypcmikefixmypcmike Posts: 19,690
    In the upper right corner of the viewport, above the cube, is a round ball -- pull that down and switch it to "Smooth Shaded".
  • Panzer EmeraldPanzer Emerald Posts: 727
    ... Well, now I feel like an idiot for not noticing that sooner! D:
    (Eh, I needed to do a fresh reinstall anyways, haha)
    Thank you both so much!!
