What happened Environments in the Render Setting pane?
I was just using DAZ Studio changing HDRs in the Environment map slider and got out of DAZ and restarted it and it has disappeared. How do I change the environment map?
If you hit the render button it should pop up the environment options node. Or you can add yourself with the create menu.
The environment settings will not show until Iray is engaged
The Enviroment & Tonemapping have been replaced with nodes. You add them to your scene by going to the Create Menu
