Horizon blur?? with Skies Of iRadiance
Ted Berlin
Hi, Just purchased all 3 of the Skies Of iRadiance and when I have them in the scene I can't find where I can blur the horizon? I realize SS "Sun Sky" has that but how would I get that done with this since they load in as hdri maps? Any suggestions?
Thanks
Post edited by Ted Berlin on
I don't think ya can but you can take it into gimp and do it there.
I don't understand your requirement. None of the iRadiance HDRIs have a hard line on the horizon. The first six of each set have basically clouds above and below, with maybe some openings showing a distand cloudscape, but no real ground. The second half all have the indistinct blurred horizon you probably want. Or do you want to blur the line of your environment against the sky?
"""Or do you want to blur the line of your environment against the sky?"""
Apparently it is the environment scene then?? I am using Isalnd House https://www.daz3d.com/island-house How can I blur that horizon line that meets with the iradiance sky?
Um-m, not really sure. Atmospheric haze or fog? Depth of field (which will also blur the sky)? Maybe some gurus could chime in...
I tried the haze and fog and it doesnt do the blur on the horizon. Guess I will blur it in post as 3dmadness suggested.
I've noticed this for a long time. Here is want I would do in Studio. https://www.daz3d.com/forums/discussion/200626/how-do-i-make-an-ground-plane-in-iray-that-fades-into-infinity
As a cutout opacity grayscale image to gently fade. Another option is to put some clouds at the horizon to break it up.
