How did I do something?
Drogo NazhurDrogo Nazhur Posts: 1,283
edited April 2022 in The Commons
I rendered the first image a couple of years ago AND a few releases of DAZ ago. I started playing with the character positions and when I rendered today (second attached image), I lost that spotlight effect. How do I get it back?
anyone?
Post edited by Drogo Nazhur on
  • Drogo NazhurDrogo Nazhur Posts: 1,283
    edited April 2022
    I have everything looking the way that I want in the editor but it renders without the spotlight effect
    1401 x 997 - 1000K
  • blazblaz Posts: 261
    Try raising luminance of the spotlight.
  • Was one version of the render done in 3DL and the other in Iray per chance?
    e.g. 3DL lights won't show in Iray
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    I did not know 3dl lights didn't show in iray, I'll have to remember that...thanks
    Both were done in IRAY
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited April 2022
    *Nevermind, your screenshot answered my question. Not sure what's going on. Maybe try changing to scene-only mode instead of dome and scene to see if the light shows up at all?
    Post edited by AlmightyQUEST on
    It isn't showing up in the shader tab so I'm not sure how to do that
    edited April 2022
    Just tried scene only
    ... didn't help. but thanks anyway
    1000 x 1000 - 190K
  • PetraPetra Posts: 1,157
    Try to add a wall behind them and see if that helps.
    i want a transparent background
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,497
    did you have the headlamp on?
  • rosselianirosseliani Posts: 508
    Not sure what you mean by "in the shader tab". You will find the spotlight parameters in the Lights Tab.
    471 x 614 - 43K
  • ioonrxoonioonrxoon Posts: 896
    Is the spotlight the one you saved in the older version you mentioned? If so, create a new spotlight and see if that works. Maybe some things chaged since that version.
