Render Quality Control Panel
dragon1_logatadragon1_logata Posts: 8
I've watch the Rendering Tutorials and they all show this Render Speed/Quality "Drop Down Panel." I'm learning DS 4.7 Pro.
I've searched the Render Settings Panel and can't find Diddly-squat! Click here, click there, go over here and over there.
Hot Dang! I know DS is deep but wouldn't you think to place the Obvious in an Obvious place?
Nowhere in the pdf files is there directions. I desire to create images for Print (High Rez 300 dpi) as well as Online (Low Rez 94 - 72 dpi.)
Any help and or direction is greatly appreciated. Thanks in advance.
All the best
  • Richard HaseltineRichard Haseltine Posts: 109,357
    This was changed in 4.7, to make the render Settings pane work like other panes. Go to the Advanced tab of render Settings and use the Engine setting - 3Delight is the top quality setting, the oepnGL options match the lower settings.
