Hand-morphs export?
Hello,
I wonder if it´s possible to export hand-morphs as Joint Controlled Morph or whatever it´s called..
Now when export lets say CTRLlHandFist, it looks like this. Can´t animate it, works only in 0% or 100%
Is it possible to controll the joints movement with morph export?
Joint controllers are, as their name says, master controllers that set several rotations. They aren't morphs, which simply move the vertices along a line between the start point and the morphed point. How are you trying to export, to what destination?
Ok. FBX to C4D. Maybe I can use some expresso to set it up.?
Maybe, I'm afraid I don't know C4D at all.
Yes, this is not Daz related anymore, thanks anyway!
