dForce Surface parameters for wet dForce hair?
When working with dForce hair is there a way to make it stick close to skin, clump together as if figure just came out of the water? What parameters under surfaces/simulation or any other settings that I can play with to accomplish that, if any at all.
  • FSMCDesignsFSMCDesigns Posts: 12,846
    You coud try increasing the gravity in the sim settings and then make sure to add a smoothing modifer to the hair so it collides with the figure more closely
  • bf2011bf2011 Posts: 155
    Thank you!
