How do I Import Hair inside "Create/Edit New Strand Based Hair" Utility ?
I used the Strand baced hair utility before to put hair on a figure, but when it comes to trying to import a hair I have no idea what to do after I press the Import button.
As illustraded in an image below I have chosen a sculp of Ingrid Hair as an object onto which i wanted to import Ingreed hair so that i could style it in the way that I want.
So after i pressed Import button a directory opened up, from which i navigated to the Ingreed Hair folder with a bunch of different files, I chose one and some long message popped up, altered the way sculp looks in the display window but other than that nothing happenned.
If someone has ever used this function susessfully can you please tell me how to use it, what type of files to choose to import and so on, because I'm completely at a loss with this, could't find any tutorials on you tube, need to know what im doing wrong.
Thank you
  • bf2011bf2011 Posts: 155
    Is it because I cant Import Actual Strands of Hair, only the textures?
  • Richard HaseltineRichard Haseltine Posts: 108,729
    You can import the distribution maps, but not - if this is not strand-absed hair but rather dForce hair - the styling, as far as I know.
    edited April 2022
    The one I tried was a dForce,gonna have to try a different one. Thanks!
